View Ping Probe History
View the ping probe history to view the history of ping tests performed by the switch.
Troubleshooting using ping and traceroute is not supported on EDM. For more information, see VOSS Release Notes. As an alternative, use CLI.
- From the navigation pane, expand .
- Select Ping/Trace Route.
- Select a ping entry.
- Select Ping Probe History.
Ping Probe History Field Descriptions
Use the data in the following table to use the Ping Probe History tab.
Name |
Description |
OwnerIndex |
Specifies the owner index |
TestName |
Indicates the name given to the test. |
Index |
Specifies the index number. |
Response |
Indicates the amount of time, measured in milliseconds, between request (probe) and response, or when the request timed out. Response is reported as 0 when it is not possible to transmit a probe. |
Status |
Indicates the status of the response; the result of a particular probe done by a remote host. |
LastRC |
Indicates the last implementation-method-specific reply code (RC) received. If ICMP Echo is used, then a successful probe ends when an ICMP response is received that contains the code ICMP_ECHOREPLY(0). |
Time |
Indicates the timestamp for this probe result. |
